disco-dad Posted March 17, 2012 Share Posted March 17, 2012 hi everyone,whilst doing my cambelt i noticed that the crankshaft damper behind the crankshaft pulley has a crack in the main part next to the woodruff key slot.i would like to change this part as there is also a groove in the shaft where the oil seal has worn away.does anyone know where i can get one of these. also whilst i'm on,would aftermarket gaskets and front cover oil seal be ok or should i try to get genuine,oil seal i can get but gaskets all seem to be aftermarket ones. thanks Martin Quote Link to comment Share on other sites More sharing options...
landroversforever Posted March 18, 2012 Share Posted March 18, 2012 As its a 200tdi part, I'm not sure you will find any new genuine parts very easily. OEM and aftermarket will be available though Quote Link to comment Share on other sites More sharing options...
fozsug Posted March 18, 2012 Share Posted March 18, 2012 You can get from here genuine but i dont think you will at the price £ 757,57 for the pulley and damper!!!!! http://www.brit-car.co.uk/search.php?xSearch=err751&submit.x=12&submit.y=14&submit=Search Quote Link to comment Share on other sites More sharing options...
disco-dad Posted March 18, 2012 Author Share Posted March 18, 2012 Think i'll just use the old one.if i hadn't taken it off i would have been none the wiser about the crack.Couldn't believe that price!!! ps just gone onto the site,they do a pattern part for £50 +vat but unsure whether to get it or continue to use what i've got.the crack is quite long but i dont know how long it has been in there,may be worrying for nothing and not sure what would happen if it got worse and failed Quote Link to comment Share on other sites More sharing options...
western Posted March 18, 2012 Share Posted March 18, 2012 same part as used on the older 90/110 n/a diesel & TD engines ETC4077 http://www.thexmod.c...ail.asp?id=1538 http://www.johncradd..._no_air_con.php http://www.lrseries....INE-PULLEY.html Quote Link to comment Share on other sites More sharing options...
disco-dad Posted March 18, 2012 Author Share Posted March 18, 2012 thanks for the links, very helpful l Quote Link to comment Share on other sites More sharing options...
