barriesheene Posted March 22, 2012 Share Posted March 22, 2012 Hi guys. This should be a nice easy one for somebody . When I first start the truck it surges for a while before settling down. For the first couple of minutes if I blip the throttle it'll cut out and be an absolute bmgnhjyrot to get started again. If I leave it for a bit to tick over its fine. It's not a cataclismick problem I admit but I would like to get her spot on mechanically . Any help much appreciated. Quote Link to comment Share on other sites More sharing options...
stuck Posted March 22, 2012 Share Posted March 22, 2012 What engine? Petrol or diseasel? Quote Link to comment Share on other sites More sharing options...
barriesheene Posted March 22, 2012 Author Share Posted March 22, 2012 Sorry guys. I thought it was under my profile pic. 3.9 v8 petrol discovery 300 model. Quote Link to comment Share on other sites More sharing options...
barriesheene Posted April 10, 2012 Author Share Posted April 10, 2012 Not that easy obviously . I thought I had cracked it. I changed the viscous fan clutch and it ran like a dream for a few days tthen last night started again. Quote Link to comment Share on other sites More sharing options...
simonr Posted April 10, 2012 Share Posted April 10, 2012 My guess would be a sensor issue. Could be as simple as the temperature sensor - if it's reading low, you will get the cold start enrichment which will cause the engine to surge, particularly if not that cold. When you blip the throttle, the mixture becomes over-rich, and stalls. When you try to re-start, it's still adding the enrichment, but it doesn't need it so doesn't start. Once it has warmed up, the sensor reads high enough to stop the enrichment and so it runs normally. My guess would be that when you changed the fan clutch, you disturbed the connection to the sensor, enough to clear the problem temporarily. On that basis, it may just be corrosion / oxide on the sensor connections - so try cleaning them first before changing the sensor. Si Quote Link to comment Share on other sites More sharing options...
barriesheene Posted April 10, 2012 Author Share Posted April 10, 2012 Likeing the sound of this Si . You may have just gone to the top of my christmas card list Quote Link to comment Share on other sites More sharing options...
simonr Posted April 10, 2012 Share Posted April 10, 2012 Si Quote Link to comment Share on other sites More sharing options...
