Mark Adams Posted April 16, 2012 Share Posted April 16, 2012 Hi, Has anyone found a tool other than the LR Special tool to remove the fuel pump on a 1.8 freelander? Mark. Quote Link to comment Share on other sites More sharing options...
Donald Sherburn Posted April 17, 2012 Share Posted April 17, 2012 Large flat bladed screwdriver & rubber mallett, tap gently but firmly & it will undo. Note!!!... when replacing fuel pump place rubber seal in tank FIRST and then pump body, if you try to place body with seal attached in tank you will not be able to screw on the securing cap. I spent 2 hours with foot on cap, mallett in hand & unlit fag in lips due to petrol fumes. When fitted tap cap to tighten with mallett. Quote Link to comment Share on other sites More sharing options...
RJF Posted April 17, 2012 Share Posted April 17, 2012 Do you mean the in tank one? I used a blunt wide screwdriver and a rubber mallet to drift the retaining ring round quite successfully on my TD4. Rob. Quote Link to comment Share on other sites More sharing options...
Blippie Posted April 18, 2012 Share Posted April 18, 2012 Ditto Drift and hammer. Quote Link to comment Share on other sites More sharing options...
