JourneyMan Posted April 16, 2012 Share Posted April 16, 2012 Hi, Does anyone have an tricks to split the Front Hub and Disc on a Classic. I've tried heating it, tapping it with a hammer. In all of the workshop manuals, it looks simple. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
minimaquinas Posted April 16, 2012 Share Posted April 16, 2012 bigger hammer and a cold chisel Quote Link to comment Share on other sites More sharing options...
Snagger Posted April 16, 2012 Share Posted April 16, 2012 Stand the inboard side of the hub on a block that fits inside the disc's void, then belt the disc with a mallet. Quote Link to comment Share on other sites More sharing options...
duncmc Posted April 16, 2012 Share Posted April 16, 2012 I did mine when it was stuck by fitting the hub back onto the wheel, then lying the wheel down with the wheel nuts facing up. Then with a drift you can work your way round tapping or wacking it off. Quote Link to comment Share on other sites More sharing options...
JourneyMan Posted April 16, 2012 Author Share Posted April 16, 2012 Cheers guys, I'll give it a go tomorrow. Quote Link to comment Share on other sites More sharing options...
Snagger Posted April 17, 2012 Share Posted April 17, 2012 The problem is the rust build up on the inboard section of the hub, where the disc has to pass over. You may have to periodically tap the disc back onto the hub seat in order to remove the build up of loosened rust that will try to jam the disc as it moves - a two steps forward, one step back approach. Quote Link to comment Share on other sites More sharing options...
JourneyMan Posted April 17, 2012 Author Share Posted April 17, 2012 Well Duncmc, your wheel trick worked a treated. And thanks to everyone else for their help. Quote Link to comment Share on other sites More sharing options...
duncmc Posted April 17, 2012 Share Posted April 17, 2012 Well Duncmc, your wheel trick worked a treated. And thanks to everyone else for their help. Glad it helped. Quote Link to comment Share on other sites More sharing options...
