mrfish Posted April 20, 2012 Share Posted April 20, 2012 I recently had my read diff fail. The outer pinion bearing failed. Replaced the bearing fine, but need to fit a new flange kit. Had a quick look on Microcat which suggested STC3722. Went to the local LR dealer who provided STC4858 but it doesn't fit. Too many splines. The existing pinion has about 10 splines (sorry but i didn't actually count). The vehicle is a 2000 model Defender 110 with a salisbury diff. When i pulled a drive shaft they had 24 splines. Looking online it would appear that the STC4457 or STC4403 should be used, but i am unable to tell which i shoud use. Any suggestions? Quote Link to comment Share on other sites More sharing options...
western Posted April 20, 2012 Share Posted April 20, 2012 STC4403 is for a 90 rear axle, reckon you need STC4457 Quote Link to comment Share on other sites More sharing options...
mrfish Posted April 21, 2012 Author Share Posted April 21, 2012 Looking on the John Craddock site they list the STC4457 as applicable up to WA. Mine is a YA. In fact it is a bit of an unusual vehicle. It is the export model that was actually made in 2003 and shipped straight out to Africa. It is basically a TD5 with a 300tdi engine fitted. I have seen on a couple of sites the STC4403 listed as being applicable from XA159807 on 1998 to 2006 (i.e. TD5) on a 90/110. Just seen the same on the Bearmach catelogue so I guess I will give that one a try. Quote Link to comment Share on other sites More sharing options...
western Posted April 22, 2012 Share Posted April 22, 2012 It is basically a TD5 with a 300tdi engine fitted. known in UK as a 'rest of world' model Bogmonster in the Falklands has one too. Quote Link to comment Share on other sites More sharing options...
