wilfred Posted April 21, 2012 Share Posted April 21, 2012 Recently had a bit of a scare.Turned ignition key on , doors locked , windows would not work , engine didn`t start & horn was going off, we were trapped in the vehicle a potential dangerous situation to be in very scary. After a while i eventually got it started but the wife wont go in the vehicle for fear of it happening again , Can anybody tell me what has happened. Quote Link to comment Share on other sites More sharing options...
Disco DJ Posted April 21, 2012 Share Posted April 21, 2012 You didn't get in the wrong car did you?! Dave PS sorry don't know! Sounds like it thought you broke in?! Quote Link to comment Share on other sites More sharing options...
wilfred Posted April 22, 2012 Author Share Posted April 22, 2012 Yep it does look as though we broke in , at least it keeps the missus out of my disco. Quote Link to comment Share on other sites More sharing options...
sierrafery Posted April 22, 2012 Share Posted April 22, 2012 it seems a passive immobilisation issue: analise this : Passive immobilisation Passive immobilisation prevents the vehicle from being started unless the authorised key is used to start the vehicle. There are only two configurations for passive immobilisation: l passive immobilisation not active l passive immobilisation active When the ignition is switched off, the vehicle remains mobilised for up to a maximum of 5 minutes. If however the driver's door is opened, after 2 minutes 30 seconds, the vehicle remains in a mobilised state for a further 30 seconds. When the timer in the BCU has expired, the vehicle is immobilised. Once the ignition is switched on, the BCU transmits a coded signal to the ECM. If the coded signal does not correspond to the programmed code in the ECM, the ECM is inhibited and the BCU inhibits the starting circuit. In order for passive immobilisation to occur, the following conditions must be met: l Driver's door closed. l Fuel cut-off switch not tripped. l Key not inserted in ignition. Passive remobilisation Whenever the vehicle is immobilised, passive remobilisation of the engine occurs when the ignition is switched on, allowing the vehicle to be started. There are three configurations for passive remobilisation: l Passive immobilisation not active. l Passive immobilisation active. l EKA with super locking on receiving good passive remobilisation exciter coil signal. The BCU controls the passive remobilisation exciter coil (located around the ignition barrel) to generate a magnetic field which causes the handset to transmit a remobilisation signal. The BCU receives the signal and allows the vehicle to be started. If a valid signal from the handset is not received within one minute of the ignition being switched to position II, the BCU stops the passive coil from generating the magnetic field. Quote Link to comment Share on other sites More sharing options...
NickMc Posted April 24, 2012 Share Posted April 24, 2012 Sound like water has got into the ultra sonic roof sensor. Quote Link to comment Share on other sites More sharing options...
kocr_bec Posted February 1, 2013 Share Posted February 1, 2013 If this is the solution, I will be very thankful !!! My topic is about almost the same problem: http://forums.lr4x4.com/index.php?showtopic=81451 Will check it out tomorrow Quote Link to comment Share on other sites More sharing options...
kocr_bec Posted February 5, 2013 Share Posted February 5, 2013 If this is the solution, I will be very thankful !!!My topic is about almost the same problem: http://forums.lr4x4.com/index.php?showtopic=81451 Will check it out tomorrow My Disco doesn't have ultrasonic volume control :-( Quote Link to comment Share on other sites More sharing options...
