barriesheene Posted May 2, 2012 Share Posted May 2, 2012 I've found out where the water is getting in to the rear boot area of my disco. Apart from the door seal and window seals . When removing the inner wheel arch rubber seal and cutting the outer arch I've found a cabbage sized hole either side !!!! Problem is its behind the dickie seat panel and I cant see how to get it out. Any idea's ??? If anybody is having water in their boot probs I'd sugest looking here cos it looks like it could be a common prob. Without removing the rear panel or interior of the boot completely you'd never know on a standard car. Quote Link to comment Share on other sites More sharing options...
barriesheene Posted May 2, 2012 Author Share Posted May 2, 2012 Ok, think I've sussed it ??? Remove seat squab and back and then remove frame > Then remove panel ?? I'll take some pics and put it in the tech forum. Quote Link to comment Share on other sites More sharing options...
Stevie D Posted May 2, 2012 Share Posted May 2, 2012 It's a common rot place! You need to take the dickie seats out to get the interior panel off - real pain in the ar$e, with 5-6 torx screws / bolts holding each side in. Steve Oops - you've replied whilst I was typing this... Quote Link to comment Share on other sites More sharing options...
