Mark Adams Posted May 5, 2012 Share Posted May 5, 2012 Hi, Bit of a strange problem, I need to replace the O2 sensor on a 1.8 freelander. I have managed to remove the old one (with a struggle), but strangly the new one does not fit in the hole in the manifold, (it will push in part of the way but it is very tight and will not go in far enough to reach the threads). I seems to be catching on the inside of the manifold. Due to the location it is not possible to see what the problem is. I can refit the old sensor no problem. I have noticed that the slits on the old sensor seem to have been almost closed (maybe on the inside of the manifold). Has anyone else had a problem reftting an O2 sensor? Mark. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted May 6, 2012 Share Posted May 6, 2012 Is it a genuine one or aftermarket? Quote Link to comment Share on other sites More sharing options...
Mark Adams Posted May 7, 2012 Author Share Posted May 7, 2012 It is an NGK sensor, it looks the same as the old one. Is the fitting for the sensor very tight? Unfortunatly you cant see inside due to the stupid design. Mark. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted May 7, 2012 Share Posted May 7, 2012 Can you bend a bit of wire and poke that in the hole to have a feel? You could always clean the old one up by heating the end with a blowlamp till it's cherry red, usually you can measure a signal coming off it when you do - should be in the 0-1v range, probably 0.8 ish as your blowlamp will be running a bit rich usually Quote Link to comment Share on other sites More sharing options...
Mark Adams Posted May 7, 2012 Author Share Posted May 7, 2012 I have a Fluke oscilloscope which I used to test the sensor while running the car, it switches from .2 to .9 but it is slow at 2.3 second per cycle. Should the inside of the manifold be completly open as I could just about feel a piece of metel sticking out just after the threads. Mark. Quote Link to comment Share on other sites More sharing options...
