No life in my startermotor
Hi all,
I've removed my V8 (ex SD1) because it was getting very very tired.
Last weekend I put a salvaged early Defender V8 engine in.
At the moment I can't get my startermotor to jump into life.
I can hear a relay click but the starter itself isn't doing anything (not even the click click sound you get when a starter is stuck)
Here's what I did:
I ran the positive cable from the battery straight to the starter (the solenoid)
Four thicker brown cables (comming from the car's wiring harness) all joined together in two ring-terminals hooked up the solenoid also (together with the + battery cable)
One thinner cable hooked up to seperate connector on the solenoid.
There is 12 volts at the solenoid.
Battery is OK
Did I forget anything ?
Would could be wrong ?
I had now problems with the old engine and starter.
Didn't make any changes to the wiring.......
Thanks !!
Edwin
Hi Brian,
Thank you for your reply !
I take it the small spade connector is the point where the wire from the ignition switch hooks up ?
If feeding it with 12 volts results in the startermotor spinning, does this mean that there is something wrong with the ignition swith ? (or the wire running to it...)
