Repair to rear outer wheel arch to sill
DrRob
The area where the lower rear outer wheel arch meets the outer sill has rotted away both sides.
Can I get away with welding in some sheet (folded to roughly follow original contours in a "Z" fashion) instead of using the repair panels that can be bought (http://www.paddockspares.com/mwc4841-wheel-arch-repair-section-lh.html) as the rest of the arch is rot free. I thought about chopping the bottom end of a repair panel off and letting that in but they are £35 each.
The only thing I can see that may be an issue is the repair panel, like original, has a channel folded in it for the door rubber but I can't see that being a huge issue if I use flat plate....
I hope I have described the issue clearly???
Hopefully someone has been down this road already ;)
Cheers
Rob
So long as the construction meets the original standard - seam welded or spot welded as original, and nothing sticks out to cause an injury then it should be fine for the MOT.
