Lumpy tickover on start up, 300TDi
Bomag
Ive just had the cambelt changed on my 300TDi and while it was being done the front thrust washer on the cam was renewed as the cam had moved out 5mm. The rocker assembly was also removed to look down the pushrod tubes.
On picking the vehicle up the mechanic said about it being very lumpy on tickover, but as the engine was now warm tickover was fairly smooth.
The next morning it felt like it was ticking over on 3 cylinders till warm and when accelerating was chucking white smoke out the back. Once warm no smoke. The vehicle has now done over 200 miles since the belt change.
Prior to belt change the engine ran sweetly from start up.
Does anyone know whats gone wrong?
