GW8IZR Posted July 2, 2012 Share Posted July 2, 2012 Hi As I'm making the new loom for my 90 rebuild I decided to use Econoseal connectors at the light fittings - same as a new one. The idea behind this is to UG from the bullet cons and as I break lamps I can replace them with the current ones. So I'll make the loom reach the pos'n of the lamp fittings but fit plugs on the old lamp units for now. I need to know what pin connection on the loom for the stop and tail and indicator lamp is so that in the future I can just plug into a new fitting - If I had a new lamp fitting I could simply measure it .. but I havent. I presume the loom connector is female and the lamp unit is male ? Stop = pin X Tail = pin x Gnd = pin X Ind = pin x Gnd = pin x TIA Regards Paul Quote Link to comment Share on other sites More sharing options...
UdderlyOffroad Posted July 2, 2012 Share Posted July 2, 2012 I was going to direct you to the pdfs posted online of the later (TD5) wiring diagrams as they show the pinouts of the connectors, but I can't find the link to it at the moment (am sure an adult will be along to help us shortly). Meantime, here's a screengrab from the pdf that should help: Matt Quote Link to comment Share on other sites More sharing options...
GW8IZR Posted July 2, 2012 Author Share Posted July 2, 2012 Spot on thanks very much Matt .. Quote Link to comment Share on other sites More sharing options...
