mcc1979ian Posted July 6, 2012 Share Posted July 6, 2012 evening, having fitted an lt230 transfer box to the 90 iv got the disco hanbrake setup still connected but the question is will this work on the 90 or do i need to transfer the defender bracket over? also when i come to order an x eng disc brake do i order a disco one or a defender one? Quote Link to comment Share on other sites More sharing options...
landroversforever Posted July 6, 2012 Share Posted July 6, 2012 Order the Defender one. The reason for the disco one is to clear the lower floor on them Quote Link to comment Share on other sites More sharing options...
Briarston Posted July 6, 2012 Share Posted July 6, 2012 When I fitted an ex-Disco t/box, I drilled the 90 bracket so that it picked up on the threaded holes where the Disco bracket fitted. A suitable thickness spacer is needed on each of these two bolts. Quote Link to comment Share on other sites More sharing options...
mcc1979ian Posted July 6, 2012 Author Share Posted July 6, 2012 so will the disco bracket not work, i still have the defender bracket but would prefer to leave the disco one in place to save the hassle of changing it and drilling it to fit Quote Link to comment Share on other sites More sharing options...
landroversforever Posted July 6, 2012 Share Posted July 6, 2012 I'm not sure what the clearance differences would be using a disco X-Brake. As for the drum, just try it and see I've not looked at a disco drum so no idea if it is any different. Quote Link to comment Share on other sites More sharing options...
mcc1979ian Posted July 6, 2012 Author Share Posted July 6, 2012 up until thursday i had both transfer boxes still lying around and the only difference i ever seen between them was the bracket Quote Link to comment Share on other sites More sharing options...
