davet27 Posted July 14, 2012 Share Posted July 14, 2012 Has anyone built a megasquirt kit onto the v8 1uz engine?? Is it similiar to the LR v8?? I have bought one to go in a boat and am looking for advice to which ms to go for ie- 1/2/3 also what else i need to get the engine running good. edis8???? I have the engine complete with its original loom. Any advise would be much appriecated. Thanks Quote Link to comment Share on other sites More sharing options...
TheRecklessEngineer Posted July 14, 2012 Share Posted July 14, 2012 It seems the 1UZ is a little more complex than the Rover lump. However, MS should be able to run it just fine. I know nothing about this engine (other than what I just learned on Wikipedia) so can't really advise much. I'd suggest asking on the MS forums - you're more likely to find a broader knowledge there I think. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted July 14, 2012 Share Posted July 14, 2012 I've squirted one, no more complex than a RV8 at all, fitting a trigger wheel is a piece of cake and can be done within the timing belt housing and using the original VR sensor to drive the EDIS. Firing order is the same as the RV8, in fact the first startup I did was on a RV8 map.... You won't need much of the original loom, I'd advise taking the injector harness and binning most of everything else and start from scratch. Quote Link to comment Share on other sites More sharing options...
zoltan Posted July 17, 2012 Share Posted July 17, 2012 Sweet! I still keep looking for a cheap LS400 on the well known auction site. One day... Quote Link to comment Share on other sites More sharing options...
Simon says Posted July 18, 2012 Share Posted July 18, 2012 Bullit proof power unit, the only weakness i know of is they like a water pump these motors will do 100's of thousand of miles with just routine servicing typical Jap gem Quote Link to comment Share on other sites More sharing options...
lee2008 Posted July 18, 2012 Share Posted July 18, 2012 Microsquirt will run it just fine, no need to fit a trigger wheel, the standard 1uz one works perfectly well. Only thing we needed to fit was a map sensor and intake air temp sensor. Ignitors and coils are all standard. Quote Link to comment Share on other sites More sharing options...
