nitrotom93 Posted July 20, 2012 Share Posted July 20, 2012 Ive had all my dash off and when I've put the wiper motor back in the wipers don't seem to be going fully up to the right and stopping right in my line of sight, i replaced the park switch last year so don't think it will be that. Thanks Quote Link to comment Share on other sites More sharing options...
zardos Posted July 20, 2012 Share Posted July 20, 2012 Did you disconnect the wiper motor from wiper tube and gearboxes when you had the dash apart? The gears might have slipped if you did. You might just need to reset the wiper arm positions. When in the parked position, pull the wiper arms off the splines. Mark on the spindle a line pointing to where the arms should be parked. Turn on the wiper motor and check that the marked line does not point to a position where the wiper arms would interfere with any body work as they move. If all looks good, then turn off the wiper motor and let it park, then push the wiper arms back on to the spline in the marked park position. Quote Link to comment Share on other sites More sharing options...
nitrotom93 Posted July 20, 2012 Author Share Posted July 20, 2012 Hi, it was just hanging off the wiper tube so that is a possibility, i will try that thank you Quote Link to comment Share on other sites More sharing options...
nitrotom93 Posted July 20, 2012 Author Share Posted July 20, 2012 Also i forgot to add, I can see water running off the motor i can't tell where its coming from.. looks like from inside it! where could this be coming from? Quote Link to comment Share on other sites More sharing options...
western Posted July 20, 2012 Share Posted July 20, 2012 screen frame to bulkhead seal is probably the culprit or the gaskets under the screen frame to bulkhead hinges/joint pieces. Quote Link to comment Share on other sites More sharing options...
zardos Posted July 20, 2012 Share Posted July 20, 2012 For the water leak, other areas I would look at is the vent flap seals, or the wiper gearbox spindle seals as it might be working it's way down from the wiper spindles and all the way down the gear tubes. Quote Link to comment Share on other sites More sharing options...
nitrotom93 Posted July 20, 2012 Author Share Posted July 20, 2012 ok, its not the vent flap or the bulkhead to screen seal as I've already had the gutter sealant out on this and a can't see any runs coming down from it, i will check the spindle seals in the morning. Thanks Quote Link to comment Share on other sites More sharing options...
western Posted July 20, 2012 Share Posted July 20, 2012 did you remove the wiper arms before moving the motor, if not, the wheelbox drive gear has possibly jumped the drive cable helix & it's all sat in a different place, take the arms off, mark a top centre on the spline end & operate the motor, then switch the motor off & see where your marks are, hopefully at the top centre, if so, then refit the wiper arms so they sit lower down the screen at the off position. Quote Link to comment Share on other sites More sharing options...
