twizzle Posted July 31, 2012 Share Posted July 31, 2012 HI All i dont want to lift the discovery 1, but can i put longer shocks on it TWIZZLE Quote Link to comment Share on other sites More sharing options...
p76rangie Posted August 1, 2012 Share Posted August 1, 2012 Yes, but you would need to lower the bump stops. Quote Link to comment Share on other sites More sharing options...
Boydie Posted August 1, 2012 Share Posted August 1, 2012 Local companies do a 6" lift kit that comes with handkerchiefs for nose bleeds and little blue tablets to control excessive heart rates every time you go round hard corners, seriously why would you? Almost every weekend I go bush I end up helping some clown with a jacked-up 4WD who finds that severe angled drive shafts and over stressed universal joints are a recipe for disaster. I've driven through 38" deep water with bow waves over the bonnet and have yet to have serious water in the cabin Quote Link to comment Share on other sites More sharing options...
iomlt Posted August 1, 2012 Share Posted August 1, 2012 No you dont. I think.. buy you have to double check, you can run a plus 2 shocker and keep the standard springs. but you will need spring relocaters front and rear and string retainers again front and rear. Keep the vehicle low good thinking and make the suspension travel! Fit the new shocks and lower down and what you want is the bump stop to touch first! not the shocks bottoming out. Quote Link to comment Share on other sites More sharing options...
twizzle Posted August 1, 2012 Author Share Posted August 1, 2012 Thanks iomlt so if i put +2 shock's on and dislocation cones in place that should be ok Twizzle Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted August 2, 2012 Share Posted August 2, 2012 Will they not bottom out unless you fit longer bump-stops (bodge) or raise the shock mounts? 2 inches more shock = 1 inch longer when closed to accept the extra 1" of rod. Quote Link to comment Share on other sites More sharing options...
iomlt Posted August 2, 2012 Share Posted August 2, 2012 why bother fitting longer shocks? why not save alittle but and use dropper plates for the rear shocks and by -1 inlower front turrents. given her extra travel? I got away with this on mine and the genuine bump stops hit first. its a case of fitting things without the springs and dropping the car and see what touches. OR keep it standard and fit a locker in the back? just lift a wheel more? Quote Link to comment Share on other sites More sharing options...
