zimaria Posted August 3, 2012 Share Posted August 3, 2012 Recently when doing 50 mph and above a strange noise is being heard from the rear of the vehicle (2006 TD4 Freelander 1). The noise is sporadic and sounds like WHOOOOOOOOO and sometimes WOW WOW WOW. I am wondering whether it is a bearing or metal rubbing on metal. Has anyone come across this problem before? Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted August 3, 2012 Share Posted August 3, 2012 Try swapping front/rear tyres. Could be the rear tyres have worn castellated. Failing that, could be diff pinion bearing or the viscous coupling bearings, you can drop it down & spin them by hand to feel them. If they do need changing, fit genuine ones - non-gen are noisier even when OK. Quote Link to comment Share on other sites More sharing options...
Dezzie Posted August 17, 2012 Share Posted August 17, 2012 I had something similar on my year 2000 FL. With mine, it was OK until about 38mph, then I would get the 'woo woo woo' noise from rear. My mechanic mate told me it was the rear diff. Had it changed - noise still there ! Land Rover Specialist said it was VCU and bearings. Had them changed - noise still there ! Eventually changed the rear tyres as on the M.O.T the guy noticed they had worn unevenly and "castleated" Changed rear tyres for new ones ......... Noise went .......... Yippeeee ! Cost me £1200.00 in total to find out though ! Quote Link to comment Share on other sites More sharing options...
garysoldierboy Posted October 7, 2012 Share Posted October 7, 2012 Hi fridgefrezzer is on the right track, try that first. Quote Link to comment Share on other sites More sharing options...
