jackmac Posted August 8, 2012 Share Posted August 8, 2012 Have been playing about fixing my winch today, and noticed what looked like a crack down the front left dumb iron. Being the fool that I am, I decided to investigate further with a wire brush and screwdriver As expected, it's nothing good! The whole chassis is getting to the point where it needs replacing, but I just don't have that sort of money at the moment. I suspect the chassis has split after a very sharp pull on the jate ring that was there (not deliberate). Do you reckon I could have the repair done with sheet metal, and just weld a patch in there, or do I need to look at a replacement dumb iron? This might explain why my bumper is not level with the body work! Pics attached Quote Link to comment Share on other sites More sharing options...
western Posted August 8, 2012 Share Posted August 8, 2012 cut out the damage & replace with new metal not less than 2mm thick, that should restore the integrity. Quote Link to comment Share on other sites More sharing options...
jackmac Posted August 8, 2012 Author Share Posted August 8, 2012 Cutting out the red rectangle in the attached photo and then just welding a new patch in would be OK then? Quote Link to comment Share on other sites More sharing options...
western Posted August 8, 2012 Share Posted August 8, 2012 should be fine provided the welding is very good. Quote Link to comment Share on other sites More sharing options...
unclemicky Posted August 10, 2012 Share Posted August 10, 2012 I got a new mig (gas) welder at work and plated over, just like Western said.Worked out well. A mig is the way to go!! Quote Link to comment Share on other sites More sharing options...
