ANTOINE Posted October 18, 2012 Share Posted October 18, 2012 Hi, who have do it, on the down of page http://www.v8engines.com/carbs-2.htm#gems if i want put a gems MAF on hotwire, what trimmer i need ? and the ecu genuine can run the engine same before ? thanks Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted October 18, 2012 Share Posted October 18, 2012 ER "Non" Yes you can upgrade the AFM, but it will then run weak without a rechip Trim would be the Green Non Cat to give max fuelling , but make sure you are not running cats All in all, IMHO not worth doing as a mod on its own Nige Quote Link to comment Share on other sites More sharing options...
ANTOINE Posted October 18, 2012 Author Share Posted October 18, 2012 Hi, this is not for my engine, i wait your offer for MS this is for my friend, he have do a twin plenium on his range rover, he have HW no catalist, we have thinking that as he have a twin plenium, the flow of air can be restrted, and when we have see this modification with gems anf trimer, we have thinking taht will be a good solution, so, if i understand good, you think this is not a good solution ? what is the risk ? if he keep the same value ohm between the HW MAF and the trimer, what happenning ? i would like your peace of advise, and if you could, with simple word for not disturb my poor english language, thanks a lot Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted October 18, 2012 Share Posted October 18, 2012 Too weak = heat and piston crown damage Needs the ECU rechipped for changes to not have risk of damage Nige Quote Link to comment Share on other sites More sharing options...
ANTOINE Posted October 18, 2012 Author Share Posted October 18, 2012 thanks a lot Quote Link to comment Share on other sites More sharing options...
ANTOINE Posted October 18, 2012 Author Share Posted October 18, 2012 just a last question, he have a tornado cheap, so he must do remapping his tornado ? Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted October 18, 2012 Share Posted October 18, 2012 Yes Tornado chip is a EPROM Chip can can be reprogrammed but its a skilled job and will need the right software and rolling road Nige Quote Link to comment Share on other sites More sharing options...
ANTOINE Posted October 18, 2012 Author Share Posted October 18, 2012 ok, thanks a lot Quote Link to comment Share on other sites More sharing options...
