LR NUT Posted November 5, 2012 Share Posted November 5, 2012 Just started hearing an electrical whinning noise (best way to descibe it) when the car is turned off. Moslty when engine has been warm. Its a mix between a slight whine and buzzing noise last about 7 seconds and always fades out. It is like something is settling down in the engine. Had the hippo from new td4 £30k on clock now, no FBH fitted. Never had this before..... thanks in advance Quote Link to comment Share on other sites More sharing options...
EggNChips Posted November 6, 2012 Share Posted November 6, 2012 It's something to do with the ABS pump, all my Freelanders have done it, although not entirely sure why. Quote Link to comment Share on other sites More sharing options...
RJF Posted November 6, 2012 Share Posted November 6, 2012 Mine does this. A Buzz that fades away. I think my noise is coming from around the EGR valve. Rob. Quote Link to comment Share on other sites More sharing options...
defv890 Posted November 8, 2012 Share Posted November 8, 2012 Hi It's your throttle body at the front of the engine near the radiator it's driven by a dc motor that's why it makes that noise ( throttle body is used to create a vacume for the egr system to flow ) Quote Link to comment Share on other sites More sharing options...
EggNChips Posted November 13, 2012 Share Posted November 13, 2012 Hi It's your throttle body at the front of the engine near the radiator it's driven by a dc motor that's why it makes that noise ( throttle body is used to create a vacume for the egr system to flow ) It's a TD4 so therefore doesn't have a throttle body. The Vacum pump on a diesel creates the vacum for the EGR and Turbo actuator, etc. Quote Link to comment Share on other sites More sharing options...
LR NUT Posted November 13, 2012 Author Share Posted November 13, 2012 Hi guys thanks for the input I have an egr bypass fitted. Is this still normal? Like I said never heard it before and have had the bypass fitted 9 months ago. Quote Link to comment Share on other sites More sharing options...
