Smoky Posted November 12, 2012 Share Posted November 12, 2012 Hi, I have a engine vibration on my disco 300tdi, it cannot be gearbox,propshafts or any suspension problem as I noted that when I rev up to between 2000 & 2200 revs the vibration comes through when standing still, anyone help/advice please. Thanks Quote Link to comment Share on other sites More sharing options...
tjolliffe Posted November 13, 2012 Share Posted November 13, 2012 Sounds like broken engine mounts to me. Check and replace if required. Quote Link to comment Share on other sites More sharing options...
Smoky Posted November 19, 2012 Author Share Posted November 19, 2012 Thanks,Replaced engine mountings about 2 months ago, vibration appears around 2000rpm. Anyone??? Quote Link to comment Share on other sites More sharing options...
Smoky Posted November 19, 2012 Author Share Posted November 19, 2012 Can it be timing belt too loose as I red in tech archives regarding installation of timing belt????? Quote Link to comment Share on other sites More sharing options...
lyron Posted November 19, 2012 Share Posted November 19, 2012 same on ours, turned out to be crank shaft damper pulley. although it did not appear to have much play, but what a difference it made, hope you get it sorted because it does tend to drive you nuts. ron. Quote Link to comment Share on other sites More sharing options...
cavenaghi Posted November 27, 2012 Share Posted November 27, 2012 Did you fix the problem in the end? Quote Link to comment Share on other sites More sharing options...
Smoky Posted December 14, 2012 Author Share Posted December 14, 2012 Did you fix the problem in the end? Not yet, still have this vibration, replaced clutch kit and oil seal a few months ago, wonder if machanics messed up somewhere eg flywheel or whatever else , if someone can advice before I start stripping. Thanks Quote Link to comment Share on other sites More sharing options...
Deej Posted December 19, 2012 Share Posted December 19, 2012 if someone can advice before I start stripping. Thanks Don't do it, there are plenty of less demeaning ways to make money Quote Link to comment Share on other sites More sharing options...
