PWM Fan Controller?
ajh
Has anyone found a plug/play PWM type fan controller to get the heater box fan with some reasonable control? I'm sick of either freezing or overheating, heater controls should not be binary... they should be a 1-10 type thing.
Oh mind is only used for heat, and puts out plenty of heat on high, and on low it only struggles due to some missing door sill sealing I still need to deal with, or if I'm rear venting to try to reduce humidity. I actually found another thread with a link to a PWM controller which I ordered and will be giving a try.
I'm also totally eliminating the cable controls at the same time. Hopefully in the end I'll also do a modified binnacle and mount so I can use the extra space too.
