changing plug leads 4.0L V8
mudmagnet
Although it is tight you can normally do it by feel, replacing one lead at a time. It's not easy but by accessing it from both sides of the car it is possible. If you have LPG you might find that the installers have run a pipe over the top of the coil packs making life doubly difficult, in which case you may need to remove the top half of the inlet manifold.
It can be done, and you will bruise the back of your hand. Make a drawing you understand of the locations of the leads relative to the coil packs. Looking after is confusing.
Also, a screwdriver is useful to prise off from the coilpack. You bruise your hand trying to get them back on.
If you can afford it, do it!
Someone on my thread said his local garage gets the girls to do it, small hands and makes sense.
With patience it can be done, and with something to lever off the firewall to click the new leads in would be ok. The biggest nightmare is getting the leads back in the holes.
