sj_4x4 Posted December 24, 2012 Share Posted December 24, 2012 Project vehicle is having a rear mounted radiator, I'm not plumbing the oil all the way to the back so plan to use a separate oil cooler, found a old Mini one, fittings are correct but the threads are wrong, anyone know of a after market kit that just fits ? Quote Link to comment Share on other sites More sharing options...
ejparrott Posted December 24, 2012 Share Posted December 24, 2012 Hydraulics specialist will have the adaptors. Quote Link to comment Share on other sites More sharing options...
mmgemini Posted December 24, 2012 Share Posted December 24, 2012 Any good hydraulics company except Pitek should be able to help you out. Northern Hose and Hydraulic sorted mine Quote Link to comment Share on other sites More sharing options...
sj_4x4 Posted December 24, 2012 Author Share Posted December 24, 2012 Any good hydraulics company except Pitek should be able to help you out. Northern Hose and Hydraulic sorted mine Hydraulics specialist will have the adaptors. Was trying to avoid that route, only local "expert" is Pirtek, used them once, not a experience I care to repeat. Quote Link to comment Share on other sites More sharing options...
ejparrott Posted December 24, 2012 Share Posted December 24, 2012 If you have a vernier calliper and thread gauges you could determine what threads you've got? Quote Link to comment Share on other sites More sharing options...
