porsche Posted January 20, 2013 Share Posted January 20, 2013 (edited) can some one please tell me what size jubilee for the fuel filler pipe to tank , also after rear tub is on any guides on running order for things to put on in order , new build , so dont know the 90 very well only discos , thanks . Edited January 20, 2013 by western Quote Link to comment Share on other sites More sharing options...
ejparrott Posted January 21, 2013 Share Posted January 21, 2013 Bulkhead, doors, seatbox, wings. Quote Link to comment Share on other sites More sharing options...
Frax Posted January 21, 2013 Share Posted January 21, 2013 Leave rear tub loose (fit rear sides)with all bolts in place then fit the bulkhead, again loose as you need to trial to trial fit the doors and do the alignment to get the doors gaps correct. A lot of trial and error but it is worth taking the time to get it correct. Buy a set of mixed jubilee clips - you will need them. I would then fit the windscreen and roof again checking the door gaps as you go. well this is how I did my one..... Quote Link to comment Share on other sites More sharing options...
porsche Posted January 21, 2013 Author Share Posted January 21, 2013 right , a lot of faffing , cannot fit wings as it has extreme wing kit which goes on cage , which needs to be painted !!! Quote Link to comment Share on other sites More sharing options...
