vernsdef110 Posted September 20, 2006 Share Posted September 20, 2006 I just converted my 110 to 300tdi with auto from a V8 with auto. I installed new exhaust but do not like how the exhaust runs under the rear link (A link). When I lift the rear and the axle articulates the A link hits the exhaust. Is this the normal path of the exhaust? It would work better if the exhaust went between the A link then bend up over the axle to the rear and out. If this is the normal path I will have to have it modified to fit my needs. Quote Link to comment Share on other sites More sharing options...
western Posted September 20, 2006 Share Posted September 20, 2006 It would work better if the exhaust went between the A link then bend up over the axle to the rear and out. If this is the normal path Yes, that's the normal route, over the rear axle & into the left rear corner behind the rear wheel Quote Link to comment Share on other sites More sharing options...
vernsdef110 Posted September 21, 2006 Author Share Posted September 21, 2006 Thanks, now I need to find someone that can make the modifications I need. Dose anyone know of someone in the Newmarket area that bends exhaust pipe? Quote Link to comment Share on other sites More sharing options...
