Simon_CSK Posted March 20, 2013 Share Posted March 20, 2013 I have a couple of issues that may be separate or related. I have noticed that when I am stationary the heating blows cold air but once underway the temperature comes up. The other thing that happened tonight was the temperature gauge started to rise. I noticed it because the power started to drop. It did not go into the red and I turned the engine off immediately and cruised to a halt. Opened the bonnet and put about 1/4 of a litre of water into the system. Drove normally after that. Any ideas? Quote Link to comment Share on other sites More sharing options...
disco_al Posted March 20, 2013 Share Posted March 20, 2013 TD5 i take it? start by checking for coolant leaks from the thermostat in the bottom hose, not normally noticeable due to the undertray. Quote Link to comment Share on other sites More sharing options...
Simon_CSK Posted March 23, 2013 Author Share Posted March 23, 2013 TD5 i take it?start by checking for coolant leaks from the thermostat in the bottom hose, not normally noticeable due to the undertray. Yes TD5 Don't think I have a coolant leak. I have never needed to to up and the 1/4 litre really only went into the space at the top of the header tank. Have today driven 250 miles and the temperature gauge which normally sits dead centre on a few occasions dropped to 1/4 of the way down indicating that it was running cooler. No other issues. Will be driving 450 miles tomorrow so should be interesting. Quote Link to comment Share on other sites More sharing options...
dooroy Posted March 24, 2013 Share Posted March 24, 2013 When I had a Td5 I noticed that the heater blew cold if revs allowed below about 1ooo - so if parked waiting for someone etc I would keep the revs up to near the 1000 mark and heater output would be fine . I also had a problem with the heater output being intermittent on occasion and was always due to low coolant level - keep a check on it in case an airlock etc has developed . Quote Link to comment Share on other sites More sharing options...
