james Posted March 25, 2013 Share Posted March 25, 2013 Hi all, on Disco Td5 2002 automatic transmission, i have both the " Manual " and " Sport " mode lights flash together. what is the problem ? thank you Giacomo Quote Link to comment Share on other sites More sharing options...
matfield Posted March 25, 2013 Share Posted March 25, 2013 Check the fluid level... mine did that every 2000 or so miles when it had a vvery slow leak. Technically the flashing lights indicate an electrical fault and needs to be brought to a dealer but check the fluid first, after that I'd be pulling the electrical connectors off and giving them a squirt with some electrical contact cleaner and then I'd look at the XYZ switch (correct me if thats the wrong name but its close) Hope that helps Mat Quote Link to comment Share on other sites More sharing options...
james Posted March 25, 2013 Author Share Posted March 25, 2013 Hi matfield thank you for answer what is the XYZ switch ? james Quote Link to comment Share on other sites More sharing options...
Dave W Posted March 25, 2013 Share Posted March 25, 2013 It's a "switch" that sits on the side of the gearbox around the selector arm. It tells the ECU what position the arm is in so it knows what gear you've selected. The switch, the connector for it and the wiring loom itself are all prone to failure, the latter normally caused by chafing. One possible indication of a problem is the gear indicator LEDs not lighting up correctly when you move the gear selector. Quote Link to comment Share on other sites More sharing options...
