Dean1989 Posted March 25, 2013 Share Posted March 25, 2013 Hi guys Just wondering if anyone knows the angle these are bent to and how far down from the front of the arm they are Bent I recall hearing 22 degrees and 6 inches or something like that could anyone confirm this please also what are the best value for money replacement front bushes (the 3 bolt triangle ones ) if that correct Any info would be muchly appreciated thanks in advance Dean Quote Link to comment Share on other sites More sharing options...
Nigelw Posted March 26, 2013 Share Posted March 26, 2013 Sorry can't help with the trailing arm bend but best value for money with the bushes are genuine parts!! Yes expensive but they are the only ones that will last the distance, if you want to go poly bush, super pro. Quote Link to comment Share on other sites More sharing options...
simonr Posted March 27, 2013 Share Posted March 27, 2013 The arms are 700mm long (give or take) The bend is to compensate for your suspension lift. Say you have a 50mm (2") lift, the angle is: ArcSin (50/700) = 4 degrees. OK, I know this is not strictly accurate because it does not form a right angle triangle, but the difference is small. 10 degrees is a common figure used however - to compensate for a variety of different lifts. Si Quote Link to comment Share on other sites More sharing options...
Dean1989 Posted March 27, 2013 Author Share Posted March 27, 2013 Cool yh i have 2 inch lift maybe i need to find some cranked arms and measure them with and angle finder Quote Link to comment Share on other sites More sharing options...
