mikec Posted May 4, 2013 Share Posted May 4, 2013 In an attempt to diagnose/fix my running issues I've bought an mtx-l now it says in the manual ""Optionally the yellow (analogue out 1) and/or the brown (analogue out 2) can be connected to the analogue inputs of other devices such as data loggers or ecus. The default analogue outputs are as follows: analogue output 1 is 0v=7.35 afr and 5v=22.39 afr. Analogue output 2 is 1.1v=14 afr and 0.1v=15afr. This is a simulated narrowband signal." So I'm guessing I need to wire in the yellow wire to the O2 pin on the relay board? Is that right. Cheers mike Quote Link to comment Share on other sites More sharing options...
Rob_B Posted May 5, 2013 Share Posted May 5, 2013 Yes, you need the yellow wire if you use the default outputs. You can change the outputs in the software, but don't need to do that. And in Tunerstudio > Project Properties > settings: you select Innovate LC-1 default, 0-5V = 0.5-1.5 lambda Quote Link to comment Share on other sites More sharing options...
mikec Posted May 5, 2013 Author Share Posted May 5, 2013 Yes, you need the yellow wire if you use the default outputs. You can change the outputs in the software, but don't need to do that.And in Tunerstudio > Project Properties > settings: you select Innovate LC-1 default, 0-5V = 0.5-1.5 lambda Cheers rob, hopefully finish it off tomos. Cheers mike Quote Link to comment Share on other sites More sharing options...
