akw666 Posted May 16, 2013 Share Posted May 16, 2013 Hello, My defender (1991 200 tdi) has begun to have problems with it's steering. When it occurs the steering feels really weird, especially in slow corners. The steering wheel moves in jerks, and tries strongly to pull back to centre. It is basically undriveable when this occurs. It only happens when the engine is well warmed up - typically about 15-20 mins into a journey. I've had local garages look at it a couple of times, but they can't find any problem (unfortunately there aren't any reliable Landrover specialists where I live). Once the vehicle has been left overnight, then it's OK again by morning. Anybody any ideas what might be causing this? Power steering pump on way out for example? Thanks AKW Quote Link to comment Share on other sites More sharing options...
Aragorn Posted May 16, 2013 Share Posted May 16, 2013 Have you checked the fluid level? Notchyness can be a sign of low fluid, overheating fluid, failing pump, split line etc etc. Essentially the pressure drops out momentarily, which causes it to feel stiff as you've lost all assistance. The pressure then returns and you get assistance for a short time then it drops out again. Quote Link to comment Share on other sites More sharing options...
Simon Smith Posted May 16, 2013 Share Posted May 16, 2013 Squirt some wd40 or similar on the column UJ's. 99 times out of 100 these are the cause of notchy steering, and though the WD40 is only a temporary fix, it should confirm whether this is the cause or not. Mine was the same, worse with the engine hot (not sure why) but perfectly ok if it was pissing down with rain, or just cold. Quote Link to comment Share on other sites More sharing options...
akw666 Posted May 17, 2013 Author Share Posted May 17, 2013 Thanks for the replies. Yes I've checked the fluid and wd40'd the universal joints. Fluid was OK and wd40 didn't seem to make a difference. Mechanic did find a leak in one of the radiator hoses so it was running hot for a while - but this has been fixed and it's still doing it. Quote Link to comment Share on other sites More sharing options...
Giles Posted May 17, 2013 Share Posted May 17, 2013 you might try draining and replacing the ps fluid (pop it in your diesel tank afterwards;) Quote Link to comment Share on other sites More sharing options...
