dantastic Posted May 29, 2013 Share Posted May 29, 2013 Recently a wire for a rear indicator shafered and shorted the indicator and while troubleshooting also the hazard fuses. Wire fixed and fuses replaced. Since this happened the indicators are no longer flashing when arming or disarming the alarm. Wasn't too pushed about that... Now there is a pretty loud beep when disarming the alarm. I have checked the 2 passenger compartment fuses. Where else can I check? I'm pretty sure there is another fuse gone and that's what the alarm is complaining about. Quote Link to comment Share on other sites More sharing options...
101sean Posted May 30, 2013 Share Posted May 30, 2013 The indicator flash on arm/disarm is fed via a different fuse (fuse 6 in the undersesat fusebox). Found this out after a Land Rover dealer wanted to charge £350 plus labour for a new 10AS to fix the same problem. Told them to poke it where the sun don't shine and after reading the electrical library on RAVE, the problem was a 10p fuse! Quote Link to comment Share on other sites More sharing options...
101sean Posted May 30, 2013 Share Posted May 30, 2013 Hi Dan, only just realised it was you! Quote Link to comment Share on other sites More sharing options...
dantastic Posted May 30, 2013 Author Share Posted May 30, 2013 Good stuff Sean! That was the one. A 15A fuse under the seat. Didn't think stuff like the alarm was fused there but there you go. Thanks! Quote Link to comment Share on other sites More sharing options...
101sean Posted May 30, 2013 Share Posted May 30, 2013 Result! If it wasn't for a certain LR dealer trying to rip my bro in law off I wouldn't have known about it! When we diagnosed it ourselves I eventually realised the flasher unit was clicking when you armed it so checked RAVE. Quote Link to comment Share on other sites More sharing options...
