10as alarm beeping when disarming.
Recently a wire for a rear indicator shafered and shorted the indicator and while troubleshooting also the hazard fuses.
Wire fixed and fuses replaced.
Since this happened the indicators are no longer flashing when arming or disarming the alarm. Wasn't too pushed about that...
Now there is a pretty loud beep when disarming the alarm. I have checked the 2 passenger compartment fuses. Where else can I check? I'm pretty sure there is another fuse gone and that's what the alarm is complaining about.
The indicator flash on arm/disarm is fed via a different fuse (fuse 6 in the undersesat fusebox). Found this out after a Land Rover dealer wanted to charge £350 plus labour for a new 10AS to fix the same problem. Told them to poke it where the sun don't shine and after reading the electrical library on RAVE, the problem was a 10p fuse!
Result! If it wasn't for a certain LR dealer trying to rip my bro in law off I wouldn't have known about it! When we diagnosed it ourselves I eventually realised the flasher unit was clicking when you armed it so checked RAVE.
