Dorsetfreelander Posted June 9, 2013 Share Posted June 9, 2013 Hello I have an 08 reg Freelander which has recently started to make juddering noise (from the engine area) on pulling away (forward or reverse). It's done 85K miles and had an MOT two weeks ago with no advisories. The clutch feels OK so we tried pulling away with the bonnet open and it's not obvious where it's coming from except that the air cleaner assembly seemed to rattle a bit (but not obviously loose). Any thoughts? Top engine mounting seems OK and car seems fine when it's going. Thanks Dennis Quote Link to comment Share on other sites More sharing options...
defv890 Posted June 10, 2013 Share Posted June 10, 2013 If the air box is loose it can make a surprising amount of noise Remove the battary cover and retry As it rattles on it To refit loosen spring clip Lube rubber mounts and gently push home Hope thus helps Quote Link to comment Share on other sites More sharing options...
