muddy4x4xfar Posted June 11, 2013 Share Posted June 11, 2013 hi all, does any one know if its possible to convert the insides of hybrid turbo to a vgt turbo on a td5 engine? cheers Quote Link to comment Share on other sites More sharing options...
Aragorn Posted June 11, 2013 Share Posted June 11, 2013 The exhaust housing is completely different. If your wanting to DIY it, then i'd look at getting a suitable VGT turbo as a complete unit off a modern car, and making it fit the TD5 manifold. IIRC Lara on here uses a GT2559V from a Renault of some description. Theres also GT2256, GT2260 and GT2560 variants on a few different cars that could all work for you. These folks have a list of common VGT turbos and give an idea of their power and performance: http://www.darksidedevelopments.co.uk/products/darkside-gtb-turbo-kit-for-2-0-16v-tdi-ppd-common-rail-engines.html Its talking about a 2.0 VW TDI, so the spool characteristics will be different (the TD5 will spool earlier) but the max performance and boost should be common. The stock TD5 turbo is a GT2052. The trickiest bit is making the VGT actuator work properly with a boost capsule, as almost all factory VGT's are either vacuum controlled, or electronic. I've had my eye on this project: http://dmn.kuulalaakeri.org/vnt-lda/ Quote Link to comment Share on other sites More sharing options...
