bishbosh Posted June 17, 2013 Share Posted June 17, 2013 Apologies but this is [whisper] Ford Focus [/whisper] related.... Am I being thick or is it acceptable to splice into the 12V feed to the power socket in the boot to supply the towing electrics loom? No I won't be using skotch loks..... The instructions seem to say (step 21 on the attached) that if you do have a 12V socket in the boot then you have to run a wire to the battery - major pain in the posterior. If you don't have a 12V socket then you just use the loose connector that is already there that is not occupied by the absent 12V socket - nice and easy. I presume this is to ensure you cannot overload the circuit by using the towing electrics and the 12V socket at the same time? Seems a bit OTT to me but I stand to be corrected by a grown up! Thanks, Towing electrics.pdf Quote Link to comment Share on other sites More sharing options...
Aragorn Posted June 17, 2013 Share Posted June 17, 2013 Your assertion seems reasonable, though if you overloaded it the fuse would simply blow. I'd just use the feed thats present. Quote Link to comment Share on other sites More sharing options...
bishbosh Posted June 17, 2013 Author Share Posted June 17, 2013 My thoughts exactly. The loom I am looking at getting for the electrics has a fuse in this feed anyhow so doubly protected... or is that a bad thing.. Quote Link to comment Share on other sites More sharing options...
Les Brock Posted June 18, 2013 Share Posted June 18, 2013 Your assertion seems reasonable, though if you overloaded it the fuse would simply blow.I'd just use the feed thats present. What he said, and you can never have to many fuses Quote Link to comment Share on other sites More sharing options...
bishbosh Posted June 19, 2013 Author Share Posted June 19, 2013 Smashing! Thanks chaps! Quote Link to comment Share on other sites More sharing options...
