disco front prop - swapped for defender td5 prop - problem?
ronnie_rotten
i removed the front prop from the disco cos the uj's need doing. i had a td5 front prop (from a defender) and as they looked the same length i put it on until i get the uj's sorted.
i seem to have vibration now, and inspection shows that the yokes are out of phase on the td5 one fitted. there is a pretty good explanation of why here...
http://i884.photobucket.com/albums/ac41/yostumpy/pshft028.jpg
so.... should i take it off und run in diff lock until the original unit is repaired, or just get the yokes in phase and put it back on again?
