jimconline Posted July 7, 2013 Share Posted July 7, 2013 1996 110 300tdi. Ive developed a grinding noise that happens fairly consistently between 30 and 35 km/hr. No other speed. Not major, but I can hear it and I can feel it through the gas pedal. More so when the road is rough. Goes away when I step on the clutch. Any thoughts? Quote Link to comment Share on other sites More sharing options...
Farmerfred Posted July 8, 2013 Share Posted July 8, 2013 Surprising no-one's replied up to now. Sounds like it's somewhere in the clutch/flywheel area and going away when you depress the clutch would suggest to me that it's something to do with the driven plate or the release bearing, something I think that you should investigate as soon as possible before things fly apart and you're stranded somewhere. Quote Link to comment Share on other sites More sharing options...
jimconline Posted July 11, 2013 Author Share Posted July 11, 2013 I’m not surprised there has been but your response, Farmerfred. I have discussed this with a number of folks, had a couple of mechanics for test runs, and no one has a definitive diagnosis. Your concern is noted, though I don’t think it has reached a point where I want to dig this deep quite yet. This puzzling problem is the most odd one I’ve experienced in over ten years and many kilometers with this Defender. I will wait to see how it unfolds. Quote Link to comment Share on other sites More sharing options...
Hazza Posted July 11, 2013 Share Posted July 11, 2013 I had this on a td5 90 at 50mph, it was a prop UJ on its way out Quote Link to comment Share on other sites More sharing options...
