Linoge Posted August 14, 2013 Share Posted August 14, 2013 Simple question: Will the LT77 from a 2.5 turbo diesel fit on a 2.25 petrol engine without any major modifications / additional part purchases? More complicated question: What could cause a 1985 LT77 behind a 2.25 petrol engine to suddenly (as in "on the trailer from point A to point B") decide that the gear shifter is only allowed to go fore-aft, and not engage any gears in the process? It's not the grub screw - I checked - the clutch seems fine, and neither I nor the mechanic currently considering the situation can get the gears to so much as grind. Quote Link to comment Share on other sites More sharing options...
western Posted August 14, 2013 Share Posted August 14, 2013 same gearbox was factory fitted on all the 4 cylinder engines but not 300tdi, so no reason why a 90/110 LT77 won't fit a earlier engine. Quote Link to comment Share on other sites More sharing options...
Linoge Posted August 14, 2013 Author Share Posted August 14, 2013 Thanks! Both the donor and recipient vehicles are D90s; just wanted to make sure they did not do anything funky for diesel vs. petrol engines. Quote Link to comment Share on other sites More sharing options...
miketomcat Posted August 15, 2013 Share Posted August 15, 2013 Discovery and range rover lt77's have a longer bellhousing. Mike Quote Link to comment Share on other sites More sharing options...
