LT77 Compatibility
Simple question: Will the LT77 from a 2.5 turbo diesel fit on a 2.25 petrol engine without any major modifications / additional part purchases?
More complicated question: What could cause a 1985 LT77 behind a 2.25 petrol engine to suddenly (as in "on the trailer from point A to point B") decide that the gear shifter is only allowed to go fore-aft, and not engage any gears in the process? It's not the grub screw - I checked - the clutch seems fine, and neither I nor the mechanic currently considering the situation can get the gears to so much as grind.
