Johannadine Posted September 8, 2013 Share Posted September 8, 2013 My land rover 3.9 V8 when i want to pull away from a stop street its like it has a flat spot and the engine wants to stall. and it does not have any power tell i push the petrol flat down. Quote Link to comment Share on other sites More sharing options...
teabag Posted September 8, 2013 Share Posted September 8, 2013 What have u checked? Quote Link to comment Share on other sites More sharing options...
Johannadine Posted September 9, 2013 Author Share Posted September 9, 2013 Hi i have checked the timing. Quote Link to comment Share on other sites More sharing options...
teabag Posted September 10, 2013 Share Posted September 10, 2013 So not a lot then. The crankcase breather so called flame trap and it hose to the plenum chamber should be clear, in the past I've found that a bottle of injection cleaner such as Redex works smoothing out the idling therefor no stalling. Simple things first so check for air leaks and hoses to the plenum are connected ok. Quote Link to comment Share on other sites More sharing options...
Johannadine Posted September 10, 2013 Author Share Posted September 10, 2013 So not a lot then. The crankcase breather so called flame trap and it hose to the plenum chamber should be clear, in the past I've found that a bottle of injection cleaner such as Redex works smoothing out the idling therefor no stalling.Simple things first so check for air leaks and hoses to the plenum are connected ok. Thank you for your advice. i will check and get back to you thank you so much Quote Link to comment Share on other sites More sharing options...
