gingerwinky Posted September 14, 2013 Share Posted September 14, 2013 Hi All, May I say first what an excellent forum this is. I am just finishing off the installation of my megasquirt system and have arrived at the tps. It is the original one (the engine is from a 1994 RRC) and does work, I have tested it with a multimeter. When I installed in onto the engine, connected it to the multimeter and exercised the throttle there was no reading. I then unbolted it and twisted it slightly and hey presto, a reading on the multimeter but the bolt holes were way out. I have looked at a replacement sensor and it has slots as opposed to just holes for the securing bolts. Should I fit the sensor as is, should I open out the bolt holes to allow the sensor to be fitted with it "just open" as per the Haynes manual or should I buy a new one with the adjustable slots? Thanks Gingerwinky Quote Link to comment Share on other sites More sharing options...
gingerwinky Posted September 29, 2013 Author Share Posted September 29, 2013 I decided to bolt it in as was, connected up the battery, hit the starter button and the beast burst into life. stunned is an understatement. Quote Link to comment Share on other sites More sharing options...
iomlt Posted October 3, 2013 Share Posted October 3, 2013 doesnt matter, just make sure you calibrate it. engine off. calibrate in close (throttle) and wide open (throttle) save etc. be fine. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted October 3, 2013 Share Posted October 3, 2013 Exactly, MS won't care, just make sure it is calibrated properly Quote Link to comment Share on other sites More sharing options...
kevindawes Posted October 23, 2013 Share Posted October 23, 2013 One thing that sometimes happens is that when you tighten the sensor to the plenum it pinches the throttle mechanism and makes it stick part open. A couple of gaskets or washers will give it enough room to move freely. Quote Link to comment Share on other sites More sharing options...
