Superflex?
Nigelw
IMO placing the radius arm bushings closer together will give less control against torque reaction, and would increase axle hop under conditions where the front axle is scrabbling for traction.
Besides, the last few seconds of the video showed the left front wheel lifting on what appears to be fairly mild terrain.
Bill nailed it there. I really hate that kit !
I think mr prop shaft will hate it too?
For a tiny bit more work it could have been a proper 4 link kit. I mean, by the time you've made up a new 'sub frame' to use the old axel mounts and made a brand new radious arm set, you're only a chassis-anchor mount 'kit' off a proper-job. It seems a bad way of doing stuff that's been better done on jeeps for years.
And I still think 'flex' isn't patch on diff locks, and flex makes it roll over easier. But there's plenty of threads on that subject ;)
