300TDi Air Cleaner Body
need4speed
Not sure if this post should be in here or the MS section. I'll let Ralph decide if it should be moved.... :)
Anyways going on advice from Nige, i want to use the 300TDi air cleaner mod on my V8. Now as i understand it i require the body itself which i think is ESR2102?
However what other parts will i need to carry out the conversion? For example what will the body bolt on to? And what hoses will i need to make it work?
Cheers
Phil
