akkers Posted December 30, 2013 Share Posted December 30, 2013 hi, i've recently got a td4 freelander mark1 (5 door) and have some electric window problems. when i got the vehicle the passengers side windows (front and rear) didn't work but both drivers side windows were ok. Now the drivers front window has packed in and is stuck approx 1 inch from the top. when pressing the switch there is no sound from the motor and after removing the door card there does not appear to be any snapped cables. The window will not push up any further from inside the door. I have checked all 4 related fuses which are ok. Because 1 window (drivers side, rear) still works i assume this rules out any relay problems.? some advice would be great if anyone could help, don't want to be buying any parts until i know exactly whats needed thanks in advance, akkers Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted December 30, 2013 Share Posted December 30, 2013 Do you get power to the motor connector when you push the switch? Are the mechanisms/motors original or replacements? Quote Link to comment Share on other sites More sharing options...
GSM Posted January 6, 2014 Share Posted January 6, 2014 I had the same problem on passenger front window, both rear windows and tailgate....in summer! On all windows except the drivers side rear the regulators were at fault....the tailgate has gone once again and have never got to the bottom of whats wrong with the drivers rear. Quote Link to comment Share on other sites More sharing options...
