Dave09 Posted January 8, 2014 Share Posted January 8, 2014 Hi have just changed the clutch master cylinder, slave cylinder and flexy pipe. All bled through ok. Now the pedal seems a lot harder than before and the bite point is right at the top of the pedal. Any advise on what to check? And the vehicles a defender 90 200tdi Thanks for any help Quote Link to comment Share on other sites More sharing options...
western Posted January 8, 2014 Share Posted January 8, 2014 have you re-adjusted the clutch pedal push-rod as shown in the workshop manual ? if not try that next, info attached below. Quote Link to comment Share on other sites More sharing options...
Dave09 Posted January 9, 2014 Author Share Posted January 9, 2014 Thanks western Yes I have adjusted the push-rod as per the manual but it's still the same. Both cylinders are OEM parts as well. ?? Quote Link to comment Share on other sites More sharing options...
