tonydrover Posted February 5, 2014 Share Posted February 5, 2014 My SII has a Rangy 3.5 V8 fitted, but it appears to have the original SII radiator fitted. The water connection from the engine manifold to the radiator has been blanked off. I would like to connect it back up but it needs the correct radiator. So.......... Will a classic range rover radiator fit into a series 2 engine bay? Quote Link to comment Share on other sites More sharing options...
missingsid Posted February 5, 2014 Share Posted February 5, 2014 Too wide I believe. I am running a Series Diesel radiator, I soldered in a pipe for the carb tower outlet which is what I assume you mean? Another way could be the use of a tee piece in the top hose, in fact there may be a top hose with it already built in from another car? Marc Quote Link to comment Share on other sites More sharing options...
Jon White Posted February 7, 2014 Share Posted February 7, 2014 No a range rover one won't fit. I just soldered a small copper pipe into the top of the radiator for this connection on mine, using plumbers solder and a blowtorch. Jon Quote Link to comment Share on other sites More sharing options...
