need4speed Posted February 12, 2014 Share Posted February 12, 2014 Got myself the brackets to mount the air cleaner housing. ERC3892 and ERC3893. I cant for the life of me see where they attach to. I thought maybe 1 end would attach to rear of cylinder head, and the other end to inlet manifold but no matter how i position it, it doesnt seem to line up. Could someone that has a V8 with standard air cleaner setup tell me where these attach to? Im concerned maybe my inlet manifold (from disco V8i) doesnt have the mounting hole i require? Cheers Phil Quote Link to comment Share on other sites More sharing options...
JeffR Posted February 12, 2014 Share Posted February 12, 2014 If the snow, sleet and monsoon abate, will nip out and check where they fit (will even take photos!) on mine, might take a day or so. Quote Link to comment Share on other sites More sharing options...
need4speed Posted February 12, 2014 Author Share Posted February 12, 2014 Thanks Jeff. Much appreciated Phil Quote Link to comment Share on other sites More sharing options...
need4speed Posted February 13, 2014 Author Share Posted February 13, 2014 Will the fact that ive an R380 fitted make any difference? Quote Link to comment Share on other sites More sharing options...
JeffR Posted February 17, 2014 Share Posted February 17, 2014 Not sure about the R380 bell housing fixtures.... Last V8 had a R380 and used the same fittings and brackets: Hopefully these photos will help: Quote Link to comment Share on other sites More sharing options...
JeffR Posted February 17, 2014 Share Posted February 17, 2014 This bloody uploader is failing pos As you can (hopefully) see, the brackets bolt to the bell housing at the back. At the front (in the engine V) they sit on a spigot via a rubber grommet screwed into a boss. Hope this is what you wanted Quote Link to comment Share on other sites More sharing options...
need4speed Posted February 17, 2014 Author Share Posted February 17, 2014 Awesome pics Jeff thanks. Just what i was after. Oddly though, the brackets look completely different to mine? Number 7 above. Quote Link to comment Share on other sites More sharing options...
JeffR Posted February 18, 2014 Share Posted February 18, 2014 My station wagon is 1991, well some of it.... Somewhaere I have the LR parts book for earlier models, will try and track it down to see if there is a difference. Quote Link to comment Share on other sites More sharing options...
need4speed Posted February 18, 2014 Author Share Posted February 18, 2014 The diagram i attached is from the old parts book. And the bracket on it looks identical to what i have (ERC3892) It looks way different to what you have fitted? Quote Link to comment Share on other sites More sharing options...
JeffR Posted February 18, 2014 Share Posted February 18, 2014 Later on today I'll strip out the bit that joins the two carbs together and get some more photos Quote Link to comment Share on other sites More sharing options...
JeffR Posted February 18, 2014 Share Posted February 18, 2014 Now all the gubbins are gone, your brackets are the same, apart from being less rusty!: Quote Link to comment Share on other sites More sharing options...
JeffR Posted February 18, 2014 Share Posted February 18, 2014 Annotated photo: Quote Link to comment Share on other sites More sharing options...
need4speed Posted February 18, 2014 Author Share Posted February 18, 2014 Bloody hell Jeff. Hope you didnt strip all that stuff off just for me!? Either way, thats very helpful indeed. Yes they are the same. For some reason they looked different with all the gubbins around them. The only thing thats different is the rubber grommet thing sitting on top of the bracket. Dont know what there for but doesnt look like il need them anyway. I can see exactly where they bolt to now. Many thanks Phil Quote Link to comment Share on other sites More sharing options...
JeffR Posted February 18, 2014 Share Posted February 18, 2014 My V8 runs twin SU's, the big black pipe in the photo below takes the air from the filter to the carbs via a single hose (referring to IMGA0015 photo above). Only takes 5 minutes to pull that lot off, needed to come off anyway as there's a snapped screw (holds the fuse box in place inside the cab) that needs removed - used as an earth for various bits, so not a prob pulling it apart. Quote Link to comment Share on other sites More sharing options...
