1/4 elliptic suspension
o_teunico
Just a doubt I have regardind 1/4 elliptic suspension. If I cut a spring at half for creating a 1/4 setup, the load rating is retained or reduced to the half?
I think the spring rate is doubled. If you cantilever mount the spring by clamping the centre to a pivot point on the chassis like on a tandem drive truck bogie, but shackle the other end of the spring to the chassis you should get good wheel travel plus a smooth ride. I think Deranged on here has done that with his SWB.
