TD5 warning light panel - ABS light won't go out
I've finally got round to installing a TD5 warning light pack, following Retroanaconda's wiring instructions here.
After a fair amount of messing around matching 200TDI wiring colours to the TD5 set (some easy, some not!) I've finally got it all working except the glow plug telltale and the ABS warning lamp. I think I know what's wrong with the glow plug light (I've got a feed direct from the plugs and not from the relay indicator pin) but I can't see why the ABS light won't go out.
I've run out of time to work on this until next weekend now, so a judiciously placed piece of black insulating tape is an adequate work around for the moment, but has anyone got any tips (or a proper explanation of how the ABS lamp is wired) to give me a head start when I next get a chance to play with it?
Thanks
Nick.
